Choosing a T-shirt fit and size might not be as simple as its seems. Even if you have carefully selected the color, quality, and design, it might still feel not right when you wear it. This could be because the fit of the shirt does not match your body shape. Therefore, don’t miss the important tips below to choose the right T-shirt fit for yourself!
What is Fit?
Fit refers to the shape and size standards of a shirt. "Standard" here means whether the shirt fits the wearer or not. There are many types of fits, from shirts to T-shirts. Although perse, the general rule depends on categorizing based on height and weight to create balance for the wearer. Here are the common types of T-shirt fits:
1. Classic Fit
Classic Fit is considered one of the first fit models in the fashion world. This fit is often called "classic" as it is loose compared to the wearer’s measurements. This type of shirt makes the wearer feel comfortable and flexible and helps cover body flaws. LionKingShirt is a famous POD t-shirt brand that offers classic fit t-shirts for men and women.
2. Regular Fit
Regular Fit is considered the standard fit. It is well-fitted and comfortable for most body shapes. Not too loose or too tight, this fit is suitable for many situations, from daily wear to work or school.
3. Slim Fit
Slim Fit is a type of shirt that is tight to the body, closely reflecting all your measurements. All parts of the body, from the shoulders, chest, waist, and lower part of the shirt, are fitted. This requires stretchy material to ensure comfort when worn.
4. Smart Fit
Smart Fit is a clever combination of Regular Fit and Slim Fit. When wearing a Smart Fit shirt, you will feel the comfort of Regular Fit along with the emphasis on the curves of Slim Fit.
5. Loose Fit
Loose Fit is a type of shirt often used in sports fashion. It is aimed at creating comfort for all movements of the wearer. The chest, underarms, and waist areas are made loose, while other parts fit just right to avoid a sloppy look. If you have a pretty thick waist, choosing a Loose-Fit T-shirt will help cover this flaw.
6. Oversized
Oversized T-shirt fit is popular among young people. With its loose and comfortable shape, an Oversized shirt helps cover all body flaws. Not only does it bring youthful and dynamic vibes, but also shows the wearer’s style.
How to Choose a T-Shirt Based on Body Shape
To choose the right T-shirt fit, first, you need to know your height and weight. Here are some tips for choosing the right T-shirt fit for different body types.
1. Choosing T-Shirt Fit for Slim People
For slim people, avoid choosing tightly fitting T-shirts like Slim Fit, as it may make the body look skinnier and less balanced. A suitable fit for slim people is Regular Fit. With a moderately wide size, it will create a slightly fuller impression. For those who are tall and slim, Classic Fit T-shirts will be the best choice. If you’re looking for a t-shirt with the right size and style for you, visit Stylish POD T-shirts for Men and Women - LionKingShirt.com.
2. Choosing T-Shirt Fit for Chubby People
Oversized T-shirts are suitable for active people
When choosing a T-shirt fit for those with a chubby body who want to hide their not-so-slim waist, avoiding tight Slim Fit is necessary. Instead, Regular Fit, with its loose shape, is still a suitable choice. Another option is oversized shirts, which can help to cover excess body fat. When choosing shirts for overweight and short people, you should go for simple patterns, slightly dark colors, short shirts, and slightly thick materials to better cover the flaws.
3. Choosing T-Shirt Fit for Hourglass Figure
When choosing a T-shirt fit for those with an hourglass figure, consider some factors to ensure comfort and style:
- Slim Fit:
Having an hourglass figure is a blessing, you have the advantage of a balanced body. You have broad shoulders and hips and a slim waist. In this case, Slim Fit will highlight the natural curves of your body. However, make sure the shirt is not too tight to avoid a constricting feeling.
- Oversized T-Shirt:
An oversized T-shirt is ideal for those who are dynamic and usually physically active. The wide and comfortable shape of this shirt will make you feel confident. At the same time, oversized shirts also tactfully cover body imperfections so that you can feel comfortable in all activities.
In short, choosing the right T-shirt fit plays a crucial role in building your style. The right fit will help you shine with a beautiful and attractive look. Otherwise, choosing the wrong fit can reveal your body’s imperfections. When shopping at Lion King T Shirt, you’ll be provided with standard size selection guide to find the most suitable T-shirt size and fit.
