Wystarczylo otworzyc strone glowna KAI i prosze bardzo od razu ten sterownik.
A Latest LED driver:
Specifications:
1- Input voltage: 0.9~4.2V
2- Ouput current: 1.0A
3- Modes: 4-group memory modes
4- Diameter: 17mm with gold coated
5- In low mode, it turns to alarm when the voltage is about 2.75V. At this time, please stop working, in case it is damaged because of over discharge.
Instructions:
1- AA battery: about 300~500mA max.
2- Brightness is controlled by single wafer, in case the over-current happens
3- New 4-group modes are completed by connecting with the five stars one after one.
4- Donot connect the wires reversely
MCU brightness adjustment (DIY):
1- 2-mode: Low(10%)/High(100%)
2- 3-mode: Low(5%)/Mid(30%)/High(100%)
3- 3-mode: Low(5%)/High(100%)/Slow Strobe(2Hz, 2 times per second)
4- 5-mode: Low(5%)/Mid(30%)/High(100%)/Fast Strobe/SOS
Note:
1- Face to the front, connect to the five stars clockwise one after one, then you will get 2 modes - 3 modes - 3 modes- 5 modes
